45 minutes ago, Travis said:
Take a look at those, these swivel up and down and side to side, so far big bumps have not moved them when in position. and come with the 3 different size clamps for different ROPS bar sizes
https://everythingkawasakioffroad.com/kawasaki-teryx-mule-rear-side-view-utv-mirror-with-three-clamp-sizes-by-moose-0640-1193.html
Thanks Travis but the bars on the door posts of the 800sx are not round and hence the trouble finding after market mirrors that I have encountered.  Check out the attached picture.
On 9/29/2021 at 7:40 AM, TapBoss said:
Might want to look thru mirrors for golf carts as well, some of those are made to bolt on flat surfaces.
Do NOT buy this golf cart mirror ...  "Cipa 01140 Golf Cart Side View Mirror."  It come with three clamping  plates that would not hold the mirror to the roll cage frame, sent back for refund.
myfirsttracker800sx
Here is my Tracker factory mirror attached to my Tracker 800SX. No wonder I couldn't find a mirror to fit the roll cage bar, because it doesn't go there.  Fits nicely at the base of the roll bar by replacing two bolts, which are provided, for a very neat, professional look.  When it is all said and done, it was worth the wait and the money, in my opinion.
    • By Paul in Wisconsin
      I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
      The service manual shows how to remove and reinstall the sway bar.
      I called Cabela's to try and get the saw bar.   They said they can't get one and the 800SX doesn't have one!!??  Then why is it listed in the service manual?? No answer from them.
      Have any of you found a saw bar that fits and what did it cost?
    • By Gary Odom
    • By carl baney
    • By Robbie Wyre
