I have 31 miles on my new T-Boss 550. In order to start I put in nentural and the emerage brake on and push down on brake paddle, then trun ket and get nothing, with key still on I shift to reverase and the back to netural and it starts. Anyone know what is happening.
Thanks for your help
I have been searching and can't find much info on these units. Pretty surprising as every other thing I own I find a lot of info on. Researching for tech info and such it's like no one owns any of these yet I see them everywhere.Â
Onto the next problem, everything has been replaced in the charging system except the Flywheel Rotor, I have it torn apart all the way down to said rotor, but it is suggested that a specific puller is required, and a compatible rotor seems virtually impossible to find. I can find many like it, but this one is mine scenario for those that get the reference. For all I know I have the last Massimo Buck 400S on the planet and will never find another part again, but who knows. Any ideas, help or otherwise that anyone might have would be greatly appreciated.
New starter solenoid....check
