I just bought a Buck 450X... right before discovering this board and reading a lot of not-so-good posts. But I hope I'm right when I believe that the squeaky wheel gets the grease, and surely there must be plenty of happy Massimo owners out there and I don't need to return my new toy to Lowe's.
So... if you own a Massimo and like it, I'd love to hear from you! Please let me know what you like and enjoy about it and if you've had only minor or no issues - compared to other posts I've read.
29 minutes ago, T-boss 410 said:
Just FYI, there's some history between Joe, Tractor Supply, and Massimo. He will fill you in.
I've read plenty of his replies to others. I'm trying to get a feel for the positive side here; not looking for airing of complaints.
Bought my 550 just about a year ago, no issues to date.  Most of the problems on here are from the earlier models that were Hisun machines, not from those that bought more recently when they switched to Linhai.
That's certainly good to know!
Love mine.
Great success dealing with Massimo getting parts
Go to any manufacture's forum and you'll run into same thing... the whinners. Just like here.
No one has yet made an indestructible machine. I once worked in a music store and the manger used to say "put a cast iron anvil on the demo floor and someone will make music with it and someone else will break it"
Bought my MSU 800 2015 new. Having some king of electronic problem right now. No fire to spare plug, no fuel; pump. Up until now has been rock solid.
Posted (edited)
I have had my TBoss 550 F (Linhai) for a year and a half. I've used it extensively and the only issue was the steering wheel screws loosened slightly. Big deal.
Updated 4/26/2024:
Been having some starting issues. The starter would stall then the engine would kickback against the starter with a bang. Was afraid that I would break the starter or damage the ring gear. So, I replaced the 300 CCA U1 Lead acid battery that was OEM, with a 350 CCA AGM U1 battery. That solved the occasional cold start stall and kick back against the starter. The OEM flooded lead acid battery is just too small. Works OK in my lawnmower, though. 😒
Issue resolved.
Edited by BlueFlag
New information
I am a retired Diesel Mec. I drive a 2016 Kawasaki Mule Pro.  I bought a Demo from the Dealer.  First thing I did when I got the machine home was to take apart every connection I could find and added Dielectric Grease.  I took every ground connection apart, cleaned the metal surface with a BRASS wire brush, coated with dielectric grease.  I use the machine for Farm work as well as hunting.  Been through 3 ft of water with no issues.  That said, if you are having electrical issues, check your powers and grounds first.  Then you can trace down any issue's
I have a 2015 Massimo Alligator 700 Wide Body I bought used about 3 years ago. The only problem I've had is overheating. Then I learned how to bleed the cooling system properly and problem gone! Only complaint I have is it is hot in the summer. Has bucket seats with the engine in between. Nice in the winter when I plow snow. I've added a tip out windshield, rear cab encloser, back up lights off road lights and electronic power steering to it. I love it, it's a beast. Oh, and I put a real temp gauge on it, but haven't needed it since I got the bleeding issue figured out. Hope this helps.
How did you bleed the air out?
Sorry have not been on the forum since that post. I don't agree with running the engine while doing this. If the engine is at operating temp, the coolant is expanded. That's the reason it has a reservoir. If the cap is replaced while it' hot it will not be full when it cools down and can create an air lock in the system. I do mine with the front jacked up and engine cold and not running. Make sure the reservoir is at the full mark before you start. There are two bleeders for the system. One on top at what looks like a thermostat housing, and one on the lower part of the water pump. Bleed the upper one first, then go to the lower one and bleed. I complete this process at least one more time, making sure the radiator stays full. let the front end down and replace the cap. I have never had it overheat since I did it this way. I used to do it with the engine running and had problems a couple times. I asw this method on a youtube video and it made sense. Hasn't let me down yet.
Just bought a T-Boss 410 for small hobby farm use and love it so far, have only had it month but use it every day.  Bought mine from Farm and Home and the guys there are great!  The speedometer didn't work but the service guys came to my place and fixed it.  Overall, very happy so far!   I got a gray colored one and am really pleased with the choice.
  • 4 weeks later...
Bought my 700  warrior used last year with 340 hrs on it, minor issues to date but love the machine, the thing is a tank . Would love to find a lift kit for it maybe some bolt on performance parts and pieces.
I have a new to me 2017 Massimo MSU500 (760 miles 103hrs). Its been great so far and its exactly what I wanted.
I am and have been doing some minor customizations:
Line Xed the bed,  Light bar with dash switch,  2" lift, Hunting graphics,  1.5" tire spacers,   rear window and these items to be done soon - Rear Bumper, Quiet Muffler, Clutch Slugs, may put 10" rim on front like is on back and some sort of cargo bags.
My only real complaint is mechanically it could use a bit more torque on low end and aftermarket parts are limited.
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Rschrem
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Tim n Deb
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
