⚠️****WARNING POTENTIAL BUYERS****⚠️
After receiving my new 2022 Tracker 800SX LE and having only 11 miles on the engine I have had it back in the shop at Cabela's several times for repair on a major safety issue. About 30% of the time when I put the vehicle in park it does not remain in park and will roll like it is in neutral. The Cabela's store I took it to has been really helpful trying to figure out the problem but I am going on 15 total days its been in their possession and they still do not know what to do as they are waiting on the next set of instructions from Textron. I have asked for a refund at this point but they are not willing to do that yet. I have filed a BBB formal compliant and told them I paid $18,000.00 cash for this machine and expected it to function as a normal operating UTV.
Cabela's and Textron have issued a stop sale or movement of any of these vehicles due to this issue. Buyers beware, this is a serious problem and will more than likely end up in a nationwide recall. I have been told by the Cabela's Maintenance Manager that this has happened to more than one customer. I hope Cabela's comes through and does the right thing by issuing me a refund as this is unacceptable.
I would think that there will be No refund (although there should be) any mechanical problem should be repairable - only question is cost.  There could be dispute between Cabela’s & Textron over $$, parts, blame assignment —— all affecting You the Customer.  I have a 2020 and no problems yet.  Would think Textron will want to avoid a recall due to the expense and damage to Brand reputation but a Recall would be best for the Customer because the repair will be correct and free.  Cabela’s partnership with Textron could also be at risk and that would motivate Textron to step up and Fix this issue.  I had concerns going with an “off brand” when I bought my Tracker but took the risk because the research & test drives I did on the 800sx we all very positive....and it was by far the “quietest” UTV out there.  I don’t believe any ATVs or UTVs are made to Automotive Standards - all seem somewhat 2nd rate compared to same parts etc...found on a Car.  Think about what you get on a base model Jeep Wrangler vs a top of the line UTV....price is very close.
Hope you get your Tracker repaired and Dealer does the “right thing”.  I don’t think Cabela’s is as good as they were prior to being bought by Bass Pro (quality & customer service has diminished) but they need to fix this for you.  Also, if anyone is ever injured because of this problem - both companies will be liable.
  • 2 months later...
2coil Fox,
Cabela's gave me a full refund. The local store I dealt with did such a fantastic job handling this situation I decided to buy another one. This time I went with the 2023 hoping I would not have the any more issues with it not going into park. They claim they have fixed the problem and it is no longer a safety issue. I have driven it up and down my property now a few days and had no issues. 🤞 Fingers crossed!
I have a 2020 800SX LE and about 300 miles/50 hours with No problems so far.  I also was cautious  about buying “off brand” but the Quiet engine and overall value/price was what drove my decision.....no regrets at this point.  I don’t race this or ride hard but it does do some “work” on my property, drags a harrow over food plots, hauls tools etc...  My concern - when shifted into gear the engine must rev up before it moves and then it “snaps” into gear (nothing smooth about it).  Once running and moving it’s fine and I can mitigate this a bit by very slowly Erving engine until I feel gear engage.  Dealer told me this is a common observation and complaint from owners but Not a problem mechanically.  The belt drive transmission is commonly used in ATVs and generally highly regarded but none of my Yamaha ATVs do this as they are much smoother.
As someone else posted - these are Not made to automotive standards but I’ve got no other complaints and had no issues in the two years 5 months I’ve owned it...the ride is great too, thatis very smooth.  One note - ..it is garage kept.
  • 4 months later...
I have had the same issue. Had back at Bass Pro, they had it for 29 days and ended up changing the whole transaxle said it was fixed. Work ok the first couple times I took it out and is doing it again. So back to the shop I go. Very frustrating for a $22k recreation vehicle.
  • 1 year later...
There is a recall on this now.  They replace the shifting cable.  My 2022 has the new cable but you still have to be aware of what gear you are in when placing it in park.
    • By Fmaxiron
      Thanks a lot!
    • By MilSurpYinzer
    • By Sidewinder
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
    • By Eman85
