Getting some work done on my sector 550 at a dealer, having issues with some parts. Dealer has tried, i have tryed, its been a month and hisun customer support has not emailed or called either one of us back.
Meantime my sector is sitting torn apart in the shop collecting dust. Apparently hisun doesnt give a ratsazz about their customers, anyone else having the same problem getting ahold of them? Sick of this crap.
