Dave needed master electrical switch Key
By great8redsfan
By todd93
Hi, all! I. I'm new to the board, hoping someone could help me out! I have a 2020 Hisun Sector 550C that I bought new in 2021. Today, I took some stuff next door to my parents. When I went to leave, I turned on the key, heard the solenoid click, but no lights, no guage activity, no fuel pump, and no starter.
The battery is good, I checked all the fuses, they are good. Not sure if the relays are good, or even what to look for there. Is it possible that it's maybe a wire?
I'm really stumped on this one! Any help would be deeply appreciated! Attached is a pic of the fuse box layout.
Todd
By didgeridoo
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
By Nypto
I just bought a new Hisun 750 sxs. I drove one mile and it just died. No power at all. Battery is 12.8v. Found no blown fuses. No power to the panel, no nothing. Problem for me is I bought 160 acres near big bend. Trying to build a house. Got blown up in 'Nam . Can't walk much. Scared I'm way out and it fails again. I heard something about a brake switch, but I have no idea where it might be.
