Wow kinarfi sorry to hear about your troubles seems like at one point or another we have all wanted to blow the trooper up lol. I found one small crack in mine a while ago had it rewelded and no issues. How many miles are on your trooper
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
On my trooper i put on 1500 miles on it since Nov when i bought it used with 140 miles at about 300 miles one of my rear swing arm broke apart so i'd say broken metal/cracks and seams are common on trooper
Sent from my Nexus 7 using Tapatalk 2
Got the engine and tranny out, separated, tranny disassembled, shaft out and take apart and reassembled and ready to put back together, not that bad really.
see instruction under
TECHNICAL ARTICLES IN THIS FORUM
http://www.utvboard....dpost__p__15261
I got a pictorial guide of what to do from Casey at JMC in the form of a PDF. file. Down load it while you can, cause if I ever need the space, it may disappear. Open Dif Inst .pdf
Kinarfi
I wouldn't quite go that far Rocmoc. First Kinarfi has to build a T2 like Lenny's. Then he can dethrone him.
Still, ain't it great that we non-mechanics can do stuff like this?
Wish I had known then what I know now, I revamped the instructions of how to take you tranny apart, and added the rest of the photos I did not use for the sake of having them available to look at. The revamped instructions make it easy to pull the roll pin.
I have the engine and tranny coupled back up and ready to go back in, and I only had one piece left over, a shim, hope it's not too important.2966196840104110397vDqtqH_th.jpg :( If anyone knows extactly where it belongs, let me know for the next time I take the tranny apart.
I still need to go under and weld all the frame cracks back together, tomorrows job.
Kinarfi
Kinarfi, I would try and find where it goes. Give Casey a call. If it went between a shaft/gear and the tranny case, the steel of the shaft/gear will eat the alum case up in no time. I really would try to put it back! JMHO!
rocmoc n AZ/Mexico
OK, Lenny moves over to occupy the throne of the immortals leaving the throne to Kinarfi for us mortals/the last 300.
rocmoc n AZ/Mexico
