t2 no start no spark
Popular Now
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By Eman85
By Rmillerdesigns
By Surfalia
Just purchased this Old Hisun and it included with a box with a brand new EPS kit. I found YouTube University installation videos and it looks doabke, but maybe the kit is made for newer models because mine doesn't have any extra open plug and play wires I see in the videos that woukd allow me to seamlessly connect the EPS wiring harness too. Has anyone ever retrofitted an EPS kit to a 16 year old model?
Thank you for any usable input offered.
Sincerely,
Surfalia
By jon pino
having trouble with a 2013 uxv500i. have replaced stator due to bad pulser coil. new unit does not work. manual value for pulser coil is 100ish ohm, measured value is 500 ohm. can anyone with one of these fuel injected later model units check their pulser coil with an ohm meter for me? left side of engine small connector next to 3 yellows. jon 605-545-7040
