  • 4 weeks later...
Glad to hear you are up & running. I traced a short or bad ground in my headlights back to the fuse box by the passengers feet. Need to remember to blow it out with air once in awhile. It was full of dirt. If it get wet, that means mud, that means short.
      Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
      Thanks for your input
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By Marie
    • By CapnWalleye
