Chery 1100 Rebuild Kit
By CSM_Retired
Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
Thanks for your input
By CaptainMorgan
I have a Bobcat 2200 Diesel (built by Club Car) with a 2-weight Team Primary Clutch I want to rebuild, possibly replace. The clutch has an annoying rattling sound at idle and appears the rollers and weights are worn and loose. When I opened it up, everything looks clean and in great shape. It's just that all the moving rollers and weights seem to have way too much play in them, possibly causing the noise. I've searched for clearance and torque specifications with no luck at all. The UTV has less than 500 hours on it. Any ideas?
By Gerald Dillman
By GBarney
Recently bought a 2010 RTV 1100 with bad engine. a d1105T out of a toro 5400 just came available locally. Looking for info on if anybody has installed the turbo version of this engine, what challenges/ problems were encountered, how it turned out.
Looks like nobody has any insight. I will complete installation and report back as to how it went, how it works, and what's involved.
By Jon Spruill
