Silverbullet
Hello i have some good news for UTV BOARD members we have made a deal with Chery Motors of Hong Kong.We can give you Members a 20% discount on all original Chery Motor Parts.These parts are original Chery parts.Not Joyner but Chery parts.Please make sure you let us know you are a UTV Board Member.We will carry all motor parts for the 1100cc & 800cc Motors.Also Chery motor parts for other company's including Renli, Reeper, John Deere 825I motors.Also the 650 Spider and Commando motor parts 2 cylinder motors.We can get complete Motors, Transmissions The discount is for motor parts only.Complete motors & Transmission at a great price.
Thank You
Matt
  • 4 weeks later...
Out of curiosity can you see if there are any bigger motors chery makes that would bolt up to our current transmission? Need mo powa, but I don't want to do a turbo if it can't be tuned. And yes I have the fuel controller.
silverbullet
Sorry I do not know what the question is.
I have checked on the 1500cc motor and will know in a few days.I do not think the transmission will work.The motor has to much torque.I have looked in to Diesels but transmission wont work same reason plus different bolt pattern.
Matt
And if anybody gets the cams. They should let Silver Bullet install them on your head. So all you have to do is unbolt it and bolt it back on. Cams and the right intake made a big differance.
Matt, what is the cost for the cam and install?
I never was sold on the cam mainly because it's just a regrind right? And I never saw any performance numbers, just seat of the pants reviews. Most of those were in conjunction with other upgrades also.
Plumber, if you are saying there is a big difference then I take your word for it.
I am not opposed to going to a new tranny & engine. Problem is finding a fwd tranny with a super low first gear.
The output shaft is the weak link in the drivetrain. I looked at having one built out of 300M. They wanted $1200. Little to steep for me.
2scoops, I like the cams I mostly always going up a hill. And they give it a little more ass. But you need to look into that other intake part it just has a better flow. Like the old corvette motor had the long intake tubes for torque. I just say it's not a hard job IF you let Silver Bullet install them on your head. I had to send mine to Rick. And he done it and send it back to me and it was done right. The first mechanic said he could do it and he bent 4-valves. You will need a fuel controller
  • 1 year later...
I will pull it out of the utv and then send pictures. But I also attached a picture I found on the internet that it looks like. I will send pics to you as soon as I can thanks
  • Popular Now
    • By AaronD1982
      New starter solenoid....check
    • By Jon W
      looking around and cannot find and Stampede motors, the Havoc looks to directly bolt in, with exception of the larger displacment. has anyone looked into this further? seems to be a better option considering stampede engines are on backorder.
    • By Robert Hamilton
      i am looking for front brake calipers and brakes for my 2008 ruesch xr side by side
      Can anybody help me
      Thanks bob
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
