Slight Differences
By hdtran
It's not immediately obvious to me how to wire a remote control (wired or wireless) on the Sector E1.
Has anyone here done this? Do you have pictures on how to get to the wiring?
By NHTracker
I have a 2020 Tracker 800SX LE that I bought new in 2020. Yesterday I noticed two cracks in the bed on the inside corners at the tailgate end. They go all the way through. I use it around the property moving firewood, dirt and stuff. Never put stress on the sides of the bed. Has anyone else had this problem? Is there a fix? Help!!!
By NHTracker
I have 2020 Tracker 800SX LE that I bought new in 2020. Yesterday i noticed two cracks in the bed in the corners at the tailgate end. They go all the way through the bed. I use it around the property moving firewood, dirt and stuff. Don't know how they could occur. Has anyone else had this problem? Is there a fix? Help!!!
By JFC
I have a 3500LB Winch that only runs in one direction. Inward but not Out. Replaced the solenoid module. Makes "click" when I push the "Out" button and the motor tries to spool out but then stops and begins to "click". Does anyone have suggestions what I should try next?
