How long is the "trip"?
Take a tool set. Sockets, Screw drivers etc. First aid kit. Water ,snacks,. Extra fuel. maybe some extra oil too. If it all possible let someone know when you plan to return.
Not to far way really. A couple miles by dirt road to 200 acres or i have access to 400 with logging roads.  Do you guys carry fix a flat or anything like that?
I carry a 12v air compressor with 2 gal. air tank attached, set @ 120lbs.. Works good if you break a bead on a tire & need volume to reset.
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Timbo
    • By malenurse13
      We bought a used American Landmaster TW450 with a Fuel Injected Kohler 440 on it. Today, I bought a Predator 459cc 15.8hp motor from Harbor Freight. But before we put the new motor in, it's pretty obvious, the stock throttle length is NOT long enough. The stock throttle cable from gas pedal to the end is only 32 inches!
      We need at least another 10-12 inches to get to the throttle linkage on the new motor. What can we do??
      Is there some way to modify the original throttle to add some length? Or do we have to buy a brand new cable?
    • By LeMay624
      Hey guys! Was wondering if anybody has had any experience in shutting up a Kioti K9 or Kioti Mechron.  I daily drive a K9 in an underground mine and between the engine noise and belt whine I can’t hear myself think while driving this thing! 2-5 hours a day. It’s a 2021 model with 180 hours on it. Belt and clutches are clean, machine is maintained to factory recommended schedule and then some. Has been like this since new. Before I start boxing in the engine with plywood and stuffing insulation under the seat I thought I would reach out and see if anybody has run into this before!
