<_< Well here is my dilemma. I just blew my rear differential out of my T2. The problem I have is Joyner wants me to go through my dealer to determine if I can get a replacement under warranty even though I have had the machine for + or - 8 months. This is all great but what about down the road if I blow another and cant get it warrantied. Joyner does not sell just the gear set (Ring and Pinion) you have to buy the whole differential complete for over $900.00(US). Ok so this is where I am coming from. I had burned up my 4X4 electronic selector months ago and when I tore it apart to repair it I hand noticed that it had Arctic Cat stamped on the electronic board inside . I did some research and found that the exact same selector is used on some of Arctic Cats ATV four Wheelers. So now I am thinking that the diff’s could also be from an Arctic Cat ATV and some look very close but I am having trouble finding one with the manual locker or even a locker at all. See Arctic Cat does sell just the ring and pinion and for under $200.00(US) A big savings from buying the whole diff. I can call Arctic Cat but I thought I would pick all your brains first to see if any of you can come up with something. This could benefit us all. Oh and to answer any questions on what happened to my diff. here it goes. Jack Ass, that’s what I call myself when I do something stupid decided to show off and spin out on dry very clean concert at a very high RPM and well yep boom blew the ring and pinion gears. Yep again, now look who’s cool. Well anyhow, below is some of the specs I have determined so far.
Ring Gear: 32 tooth
Pinion: 15 tooth
Gear Ratio: 2.13
Ring Gear Diameter: 6 5/8" 0r 6.625"
Pinion: 26 spline
ring gear: 12 bolt
No Part numbers on anything except the case and I believe it to be Joyners marking.
HTR10711130
Not to add insult to injury...... but if you destroyed it doing a burnie on concrete, why would expect Joyner to pay for the parts. On another note, I have replaced rear diffs in some quads, that dont offer just a gear set, and they can be as much as $1200. Sorry about your bad luck but I dont think you will find an atv gear set for that diff. Sorry A.
You have the info, call a artic cat dealer, have them count the teeth and splines, if it all sound the same have him ship it to you withthe understanding if it is the wrong part you can send it back, that way you would only be out shipping charges if it where wrong.
Good thinking flatbed and good luck with that latch73.
Cheers Mike
Not a cure and probably no help, but if you put the front diff in the back or at least the ring and pinion and then make the ring and pinion so they don't damage any thing else and enjoy driving your trooper without the advantage of front wheel drive. My dealer suggested stay in two wheel drive until I NEED 4 X 4 and it surprises me how far I go. :rolleyes:
One problem to that deal, I hope you like going backwards because you will have 5 gears back-wards and 1 gear forward. The drive lines are going into the diffs oppisite ways so you will be going the oppisite way.
Do not want to take your money, On 4 wheel drive vehicles the ring and pion gears are cut oppisite so that you are always loading the long side of the tooth on the gears. We had better hope that they did it on our troopers. the rear diff is correct, i have had one apart.
The teeth on the ring gear are curved. so if you picture yourself making a turn in the road the inside lane is shorter than the outside lane. The outside is curve of the tooth is longer. Sorta like water on a dam, it is curved for strength, the water bares on the long side of the dam.
L stands for long
S stands for short
Did I get it right?
and I'm still not convinced that they don't use the same ring & pinion front & rear, the diffs are rotated 180 degrees (the opening on rear is on the right and on the left for the front. As I see it, if the rear pinion is turning the front of the rear ring downward, then the front pinion will be turning the back of the front ring upward, because the diffs are rotated. (still looking for info).
the long side of the tooth would be ))) the right side of )) The short side, the side of the gear being used in reverse ))) left side. You are making me mad with how well you do pictures
You teach me mechanics & I'll teach you pictures, Do you have Microsoft photo editor, I find a photo, copy it, paste as new image into ms photo editor & save, then use paint brush to label it, open http://community.webshots.com/user/TrooperFolk, add the photo, click on the photo, click on the post in a forum link, copy, post in my message. :lol::lol::lol: EASY
I just found a diff site that I found interesting, I doubt any of us trooper drivers will use it, but you never know, lots of photos
http://images.google.com/imgres?imgurl=htt...ficial%26sa%3DN
after browsing through this link, I don't think my suggestion to move ring and pinion from front to back has any merit at all, and if I do say so my self, what a stupid idea!!!! :blink: To much work to get the correct mesh. :D
latch73
What happened as far a getting parts for the diff. did you find a ring and pion. another thing to think about is changing the gear ratio. going to a taller gear will make the ring and pion stronger. you would have to change both ends of course.
latch73
Flatbed,
I have come real close with some of the ring gear and pinions used in different ATV's. The part thats killing me is the rear locker. I cant come up with anything that uses a rear locker witch is critical do to the way the ring gear bolts on. As far as going taller if I am not goofed up would actualy make for a weaker pinion gear do to the fact that the pinion would drop in the number of teeth. Not 100% on this but if my mind is not playing with me I belive that is the way it works. The other problem is I think with taller gears I would loose alot of bottom end torque. Whats your oppinion?
In our semi trucks we run 456s, we used to run the 488s. our trucks move loads up to 300,000 lbs. the 456s are a stronger gear, you have more teeth in contact and the gear is thicker. When you run planitarys they run a high gear on the ring and pion and then lower the gear back down with the planitarys at the hub. In racing we had a problem on short tracks, (need lower gear ratio) the ring gears would break. !st gear in the trooper has plenty of torq so i don't think the gearing would kill you.
Thanks flatbed that makes good sense.
Well I am back on the road again. YeHa!!! I was able to purchase a ring and pinion set from a dealer who had a T2 come in with a busted diff. housing. FYI, If anybody breaks there gears, unless you can find a used set from someone, you will have to purchase the complete differential form Joyner because they dont sell just the gears. ($900.00 +) Well happy holidays to all.
Lance
Lance
http://images.google.com/imgres?imgurl=htt...ficial%26sa%3DN Did you have to do all the stuff in this article or just put them in place and tighten the bolts?
jeff
jeff
Jeff its kind of funny because I have set up many of chevy differentials and one Toyota and there is no adjustment on the trooper differential. It is built so it can only go together one way and does not use a crush sleeve or have any shims to allow for back lash adjustment. I didnt put a mic on it but the back lash is not to far off by just feel and sound. I have never seen anything like it and figure that is the reason Joyner does not sell just the gears.
If you get a chance, take a look at the front gears, I still think they'll be the same as the rear, after all do you think they want to go the expense to make them different when they can just turn one upside down. :D
Jeff
Jeff
I bet your right. I hope I dont have to break into anymore diffs. but if that ever happens I will investigate. It would be good to know so if anyone ever breaks some gears we would know if you could use the fronts on the rears and vice versa.
    • By Joe Rizo
      Hello All,
      1. Fuel pump (new)
      2. Fuel sensor (new)
      3. Fuel injector (new)
      4. Battery (new)
      6. fuses (12v to all)
      13. replaced air filter
    • By Gerald Dillman
    • By Ed Michael
      Subaru SxS.mp4
