I have had a Bad Boy Stampede for almost two years now. I really like the machine but it seems like everytime I run it over 40 mph for more then a couple hundred yards it starts leaking antifreeze. The mechanic says it's a seal in the water pump, I've went through three water pumps now. Does anyone else have this problem?  And if so is there a fix for this?
  • Alex changed the title to Textron Stampede leaking antifreeze
13 hours ago, kenfain said:
After three pumps, I'd verify that the pumps are actually the problem. If so, then I'd look at the aftermarket pumps. What've you got to lose?
Ok thanks. What aftermarket pump did you go with? And how has performed for you?
At this point, any reputable aftermarket parts outlet should have what you need. Very few of them are actual OEM parts. As far as exactly which one, I don't really think it matters. As long as it's different from the one you've been using. A roll of the dice is as good as what you've been getting. The OEM one likely has some sort of casting flaw, causing it to defeat the seal integrity. Unless I'm misunderstanding the problem.
When you're talking about water pump problems. There's really only the bearing, seal, and impeller. So when identifying your exact problem, you just give it a spin by hand. If it's a bearing problem, it'll feel gritty when turning it. If it turns smooth but leaks. Obviously it's only the replaceable seal. Seal kits are readily available for most of those models. Just make sure that it's a name brand pump, and preferably serviceable.
Full disclosure; I don't own a Textron, I've had some experience in water pumps though.
My Stampede started leaking at 1100 miles.  Required water pump *O* rings requiring pulled engine and $900 repair bill..  Nine hundred dry miles since.  Textron hasen't answerd  my letters about the problem.
At the risk of sounding facetious, Find another mechanic!
  • 1 year later...
I have a 2019 Articat Stampede. The dealer replaced a leaky water pump at 400 miles. I have 900 miles on it now and it is leaking again.  My mechanic at the dealership said it’s a know problem. Any suggestions for a good fix would be appreciated
    • By jertex
      I have two questions:
    • By Jon W
      looking around and cannot find and Stampede motors, the Havoc looks to directly bolt in, with exception of the larger displacment. has anyone looked into this further? seems to be a better option considering stampede engines are on backorder.
    • By Kierobi
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By schreib69
      I just bought an older (2008) Teryx 750 and am having some concerns.  Hoping of course, that most are not too big. . . but more knowledgeable folks like yourselves will surely have some ideas.  Thanks in advance.
      -- about 2700 hrs, camo version
      -- Starting:  after not running much at the auction site, I tried it and it was tough to start but half of this was likely I did not quite know the tricks for how long to keep the choke on. However, once it started it was kind of hard to keep running until it warmed up(once warmed it starts perfectly every time with no choke).  Now, back to running after the first ignition:  I had to hold the RPM's up a bit to keep it running and when doing so it sounded as if a little gnome was inside the engine pounding on something at random intervals.  Wondering if this could be detonation-- "knocking"?  After warming, it disappeared completely.  Maybe just need higher octane gas??
      -- After starting and running a bit there was a pretty terrible smell, most "like" burning rubber or an electrical fire.  No fire or resolution of this.  Eventually this TOO went mostly away, but still basically present.  Could it be adjustment needed for the main belt variable speed tranny?
      -- When I move from neutral into either Lo or HIGH range forward gears, I get gear clashing.  I did NOT put foot on brake and read in manual(just NOW) that you are supposed to do so.  (I have NOT gotten back out to check and see if this matters. )  OR, could it be part of the drive system is mashed up??!  Geez, hope not.
      -- There is a big open hole allowing direct sight into the belt transmission on the back right side.  This can't be normal, it must require some plastic cover.  Right?  Any rodent could get right into the transmission!
      -- THere appears to be no muffler or spark arrestor unit.  This "could " be the cause of some of the smell. . . ??  but that should not smell like burning rubber or electrical smell. . .
      SO.  That is all.
      I sure would appreciate any insight on this issues and finally(!). . . if I was to take this into a local dealer what would you say are the top three issues I should have them address first?
      thanks!
