Newbie T2 owner
By Xov
By Tim n Deb
By Prepper
I have been doing a little research on which engine oil is best for UTV engines. There seems to be some disagreement over using a good quality regular engine oil, and the necessity of using "M2" (or wet clutch suitable) oil. My understanding is the "wet clutch" suitable oil has less friction reduction properties (hence a more responsive clutch with less slippage). While less friction reduction properties would seem to be better for the wet clutch... it would not be best for the internal engine parts like camshaft bearings and other moving parts where friction is detrimental and would lead to premature failure. Some folks swear you need M2 oil, while others say they have been using regular motor oil for years and their clutch is just fine. Could they both be right ???
Any thoughts ?
By KWinTX
By Gerald Dillman
