Anyone playing with their Trooper this weekend?
By DLJ
Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
By Robert B
Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
By johnpeter
2023 Can-Am Maverick Sport XMR 1000R RED TITANIUM On Ebay
https://www.ebay.com/itm/156096225938?
