Guess it was my turn
By BOYD
By DLJ
Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
By Ermd ttk
Hello friends,
I got my ODES Ravager UTV yesterday and after a couple of hours of driving when I go downhill I heard a strange loud noise a couple of times, like a gear skipping or maybe something from the differential.
It doesn't always happen and when it does it is heard for a few seconds and then it goes away and everything works normally, I'm worried if there could be some major malfunction or what could be the problem if someone can help me?
Thanks a lot.
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
By mcraigchr
I realize that many of you do not have diesel machines. For those that do, this is for you:
Just wanted to post my experience this past week. Here in Texas, we had pretty good dip in temps. For 4 days it did not get above 25. At night, it was single digits or close to it. I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon). And up until this tank I was using Power Service (white bottle) for anti-gel. Never had an issue.
This tank, however, I switched to Stabil All season (anti gel). It is supposed to good down to -40. Zap. That is a big fat lie. I put in twice the amount called for in the instructions. Result was less than optimal. I drove the SxS 100 feet (to go get the mail) and it died. I looked at the fuel bowl and it was a cloudy, wax substance. So, the Stabil did not work. That said, I'm not sure that I ever tested the Power Service in the same manner. So I am not saying that one is better than the other.
What are your experiences? Are these products inferior? What do you folks in the northern states / Canada use? Am I missing something?
CC
