Milage and how did u here of the Joyners
Mine blew over when the rad fan motor burned out. Only had it for 5 months. Still, I bought another motor, cus I think it's actually a decent fan, just a bad motor. Guaranteed for life if oyu send in the warranty card within two weeks.
I got this one:
http://www.ebay.com/itm/110831358724?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
No damage to the engine. Overheat bulb was burned out too.
Link to comment
Share on other sites
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
I never installed the radiator because I'm not sure how to get around the different hoses sizes and how to Mount it yet but i do know i would want to fabricate upper Mount and modify the lower Mount and have rubber between the mount and radiator so the vibration wouldn't crack the radiator...
Link to comment
Hey got the first one in 2008 800 sand viper 1500 miles on that.Sold that needed 4x4 had the 2009 trooper now has around 1000 miles on it. Use it at coal creek tn. Lots of rock trails and gravel roads. Once you work Thru the fixes good machine. Always get lots of looks
Codyjo
Link to comment
I did a larger radiator and fan also for running in the desert. I have a few pics under my gallery. I had to make a few mods to install, but since that point I have eliminated the overheating issues even when it is over 100 outside.
I looked up your photos.. very interesting so you welded bracket on the radiator for bottom stock location and remove the top stock bracket then made new bracket welded to the radiator to bolt the radiator over to where old stock bracket rod bolts on to on the roll cage?
What did you do about the different hose sizes?
Link to comment
Let me check again and I will update what I did
quote name="nocturnalsixer" post="17890" timestamp="1374534560"]I looked up your photos.. very interesting so you welded bracket on the radiator for bottom stock location and remove the top stock bracket then made new bracket welded to the radiator to bolt the radiator over to where old stock bracket rod bolts on to on the roll cage?
Link to comment
Finally able to work on the diff. Took it apart and found the up grade wasn't done. It appears when I sent the old diff in they installed the same soft bolts which were in it. The shop here sent the diff to a Joyner dealer in AZ don't know which one. I have limited experience with this so any help would be great on how to get the diff apart and fix it. I have the side case off and found the bolts on that side sheared, no damage so far.
Link to comment
For doing yourself, order some grade 12 bolts from McMaster Carr http://www.mcmaster.com/#96144a227/=bufcy2
and grind the heads down to get the clearance needed, these are fine thread and I believe in having the shank type because that is where the two pieces meet and try to shear the bolts. I think this is the correct size, but not sure.
do a search for mcmaster and you'll see where I have suggested the earlier.
Link to comment
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By MJG
      Hello,
      I found an 08 Renegade for sale and looking to purchase it.  I haven’t heard too much about these machines and any insight would be much appreciated.  Are they good machines?
    • By goindeep
      Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
      Josh
      No Limitz
    • By lowgear52
      Does anyone out there have a rear differential for a trooper for sale?
