Fender Flares
By doncaron
Hello everyone!
First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring. I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
thank you in advance again.
By MJG
Hello,
I found an 08 Renegade for sale and looking to purchase it. I haven’t heard too much about these machines and any insight would be much appreciated. Are they good machines?
By Rizzguy
Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
After one ride, the rear bolts have disappeared, because how much tension there is on the flex
And the bolts does not line up at the flange
Have a video before and after. And they are telling me that it’s my fault because it does not fit
wtf.!
What kind of idiotic people are even answering the phones these days.?
This guy has probably only read a book and never even driven a motorcycle in his life
Don’t waste your time with this bullshit products
By goindeep
Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
Josh
No Limitz
