Stuck key
By Tim n Deb
By Prepper
I have been doing a little research on which engine oil is best for UTV engines. There seems to be some disagreement over using a good quality regular engine oil, and the necessity of using "M2" (or wet clutch suitable) oil. My understanding is the "wet clutch" suitable oil has less friction reduction properties (hence a more responsive clutch with less slippage). While less friction reduction properties would seem to be better for the wet clutch... it would not be best for the internal engine parts like camshaft bearings and other moving parts where friction is detrimental and would lead to premature failure. Some folks swear you need M2 oil, while others say they have been using regular motor oil for years and their clutch is just fine. Could they both be right ???
Any thoughts ?
By Some random dude
2015 Hisun 700 Utv
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By The Road Hound
Hi,
New to the forum.
Came here looking for some experienced UTV users who can enlighten me about which brand should I pick for my very first UTV or SXS.
I'm between 3 brands and 3 models:
*Kawasaki MULE PRO-FXR 1000.
*Yamaha wolverine rmax2.
*Can am Commander XTP.
The use I'm willing to give it is mostly to go to the range with my wife, load steel targets and all our shooting gear, we shoot a lot, rifles, Shotguns and Handguns for practice, training and competition. (Range is about 10 miles from home)
