Slow 2017 HiSun Strike 250
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By Hi sun 500
hello everyone, i just joined this forum to try my luck, few days ago i bought an old (dont know exactly), 2011/14 hi sun 500cc ""carburated"", was not running at the time, but i fell was a good deal and decided it to bring it home to play with it, this is the issue, i bought and installed a new carb, and pump, i repositioned the battery location and upgraded to a "car batt", reconnected the fuel lines and started it, but it only runs with the choke ON, i checked the bowl, it does have fuel,but for some reason wont inject it to run, i came across a video that say that ""the body small tank had to be connected for the cart to run" (was deleted when bought), sure enough i got it to run sporadically , but the so called ""small body tank'' often runs out of fuel and wont refill itself , i had to couple times do it manually, so how does that small tank works ?..what does it do?..and why if bypass it , the cart wont start?....any help?..thanks so much!!!
By aefron88
View File Hisun HS400/Coleman UT400 Parts Diagrams
Compiled document with parts diagrams for Hisun HS400/Coleman UT400 for help in repairs where the service manual diagrams are poor or non existent.
Submitter aefron88 Submitted 04/15/2024 Category Hisun
By Nypto
I just bought a new Hisun 750 sxs. I drove one mile and it just died. No power at all. Battery is 12.8v. Found no blown fuses. No power to the panel, no nothing. Problem for me is I bought 160 acres near big bend. Trying to build a house. Got blown up in 'Nam . Can't walk much. Scared I'm way out and it fails again. I heard something about a brake switch, but I have no idea where it might be.
By packersfan
I have a hisun 500 got from a auction and when turning a corner left or right it's a two hand job then when you left go snaps back.any help on what to look at would be appreciated.
Also blows blue smoke until she gets warm then it's ok
