I agree also, I had my CV drop out twice, the 2nd was from running with a blown shock, it was topping out and bottoming out real bad and sounded bad. If you're trying to go flying :lol: , you may need to stiffen your spring. I don't know how you compress your spring to ease the adjusting, but I bet you own a handy man jack, that's what I used to take my shock apart with.
  • Replies 114
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
If memory serves me correctly, the last time I jacked my T2's rear up off the ground, I had some play, but I also have let some on nitrogen out of my shocks too. My reasoning is that it should give me a softer ride and it is less likely to blow the seals out, I hope.
I also have the shocks so that they are not fully extended when sitting, if you have one wheel high on arock in the rear it letts the other tire have some weight on it. The limiting straps that rocmoc has keeps him from having the spring trying to drive the shock apart. I have a felling that where he rides he needs the ground clearance. I also have the same problem of getting myself into spots i should not be in.
My idea of a limit strap it to protect the CV and the shock when it unloads, with that in mind, collapse the shock some and take all the play out, then when you release the shock, see if it keeps the shock from bottoming and by how much. Realize that the momentum of the wheel and swing arm will stretch the strap more than just releasing what ever force you used to collapse the shock. MY DISCLAIMER, IN MY HUMBLE OPINION.
Yes, bottom out = fully extending, trying to tear itself apart.
Pics!
Rocmoc
I can see that you connected a seat belt to the bottom of the shock through the mounting hole, but I cant tell what you did on the top end, I would think it is to the frame somewhere. I like this idea, I guess I could measure the distance from the bottom mounting bolt to the frame where I plan to mount it, and maybe provide 1/2" slack at the most. My crazy thoughts, since my mind pushes a pen and not a wrench. I am learning but need direction....
I replaced our factory latch belts with a camlock setup. Take the lap belt from each side to use as the limit straps. The end that threads thu the bracket with the hole and slot is the end used for the top. Un-thread the belt remembering how to thread it back into the slider on the belt. There is a square 1" brace between the shock mount and the outside tube. Just wrap the belt around this square tube and retread the belt into the slider. The end that is fixed, can not be removed, is the end that went into the latch will be used on the bottom. This has a 1 1/2" rectangle slot. Spread this slot large enough with hammers and punches to accept the bottom bolt of the shock. Don't use heat or you will damage the belt. When you use these belts as seat belts, there was a loop in the center you could pull to shorten or length the belt. Make sure this loop is in the fully lengthen position, in other words make the belt as long as you can. Attach the metal end with the rectangle slot to the outside of the lower shock bolt, bolt is 3/4" and nut is 13/16". I had to use to large break-over handles as there was lock-tight on the treads. Attach the bottom. Run the belt up over the square tube and re-thread the belt into the slider. All this was done with a jack stand under the frame and a jack under the swing-arm to get slack so you can remove the lower shock bolt. Take everything off the stand and jack with the Trooper resting on the ground. Pull the loop as tight as you can so you remove any slack in the belt. Easier than it sounds if you have the tools. If not, find a friend who does. You have to do almost the same thing even if you buy limit straps. Good luck!
This is a shocking story? :lol: Remember that shock of mine that puked all of it's all over my swing arm. I got even with it. 2055262540104282158gncYTW_th.jpg Take a look at all of the photos.
:angry: I started sawing on it just below the seal, there was a nice notch there to keep my blade from going all over. If you wanted to use the help of a machine shop, or had a lathe, these shock could be made rebuildable, if you thought they were worth it. I did think it was pretty interesting though to see the guts of one of these things. If you were to shave off just enough of the top (or bottom since that's how it's mounted) to get the seal out, you could replace the seal, have the body threaded, and make a threaded cap to hold the seal in and just keep rebuilding it for the price of a seal & nitrogen. If you knew what you were doing, you could even make some adjustments to their dampening.
I do think that the nitrogen in them is to keep them from cavitating during compression as the plunger moves away from the seal and has little to do with the lifting of the vehicle like the springs do.
Another idea would be to remove the dampening block, put some regular oil in the tube, reassemble and then you have a coil spring with no dampening and you can add Rancho or what ever shocks.
shock guy called today. 23.35 " long 2.0 shocks with 8" of stroke with springs, These are fox shocks @ 285.00 apiece. I was very busy when he called, but i think these have 2 springs per shock
Hey... I was just trying to figure out how I could get some fox shocks for the t2... did you get the fox shocks? Did he give you a part number? lol I just really want to put some on the blue t2.:)
Hey... I was just trying to figure out how I could get some fox shocks for the t2... did you get the fox shocks? Did he give you a part number? lol I just really want to put some on the blue t2. :)
Still running stockers, had to replace one front & one rear. Today I'll get new tires and hopeful get them mounted, Photos will be posted! ;)
Sweet you know I love to see pictures!! oh... so some guy wanted Jerry pimped out t2 so bad that he bought and now we are pimpin out the blue one for him...and it has the big beautiful 30" XXL Itp tires on it so far. We are going to get a black matte top, and they are installing a computer chip in it!! bringing the hp from 86 to 108!!!!!! How bad do you think that is going to be!!!!
How much is the new chip?
Ordered 2 fox shocks for the rear last night. they are 23.35 inches long with a 8.50 inch stroke. I should be able to pick them up today. I am getting them for less than 200 apiece. Going to superstition this week-end so i should be able to give you a report on how different it feels.
Looking forward to your report, be sure to take photos.
What is the stock/model number for them.
The weathers has been bad so I haven't been out to test my tires, so no report yet. Working on mods to my hood like latch73 (Lance) did. :rolleyes:
Flatbed,
Fox 2.0 or 2.5? Are the springs included or are you reusing your existing springs? I assume from the price, no reservoir.
Did you ever get corner weights?
rocmoc n AZ/Mexico
The shocks i have are 2.0 with no springs. Tried putting the stock springs on tonight, they are to small in diamenter, you could run them but they would ruin the threads on the shock. The shocks have all the hardware for dual rate springs. I also noted at the trooper store today that they have change the location of the rear shock mounts a little bit on the new troopers. They also have a recess in the dash to put things. Any way i am going to wait untill i get back from this trip to mount the shocks. I did notice that when i had the spring off the old shock that there is hardley any rebound in the shock and the compression is pretty stiff. From what i have done with shocks i see where shocks on the trooper will make a huge difference. Rocmoc, i feel that the 2.0 will be more than what we need, i do not see where we need the reiviours either. You would have to beat this shock to death. Also these shocks are lighter than stock and not running resiviours helps also. I really want to put the trooper on a diet. I guess now i will have to get weights so i can get the new springs.
The reason I was looking at a reservoir is because when I blew my shock and let the N2 out of the other shock, the oil in both shocks was so hot I was nearly burnt. I was going over a trail that required a lot of shock action but unfortunately that is most of the trails around me.
I found the same, no rebound. Yes it will make a world of difference, one reason I am going to do the same as you and lower the diff. I have never had sag and you need some sag for great shock action.
Sorry to hear about the springs. Keep us abreast of what you do.
My Trooper will diet when going to sand/dunes. I plan to remove the back lid/rollbar over the engine and replace with a single sheet of 1/4" aluminum diamond plate. To me that is one of the easiest weight savers for the dunes. I also am going to do the same to some of the protection plate under the Trooper. I will leave steel in the middle where the high center takes place and under the engine/diff. The rest can be changed to aluminum. Let me know if you have any other ideas.
rocmoc n AZ/Mexico
Rocmoc, the 2.0 have a smaller shaft than stock, plus the valve body and tube are bigger. The shocks probably hold twice the amount of oil than stock. With the shaft size being smaller more oil has to move through the ports on rebound. I am shure you know about this , just saying for others so they know. I was amaazed at how much the stock spring is compressed on the stock shock, over 2 inches, no wonder the springs are ripping the shock apart. After looking at the stock shock i am very excited to see how we do with after market shocks. Like i said when i get back i will weigh the trooper and go from there on the springs, i will go with the duall rate.
    • By Eman85
    • By gridlock
      After three years, my Sector completely died.  Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged.  The batteries weren't charging 100% anymore, so decided to convert to lithium.
      As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed.  I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly.  I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)).  Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts.  I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
      So far, it definitely is better than with the original AGM batteries.  Sustains speed better going up hills, and seems to have plenty of reserve current.  The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
      A few questions:
      In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that.  Is there any more info about that?
      Have folks replaced the onboard 12v battery, and if so, with lithium?  I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
      Is there a recommendation as far as charging with the lithium conversion?  As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time.  What do you think?
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
    • By ChiefKen
      I had read in a pass post that there was a modification for the gEarsheft level to help prevent slipping out of gear.
      I check the parts list and the assembly is out of stock.
      Is there a design for the modification?
      Mine has been working fine up till the last week or so., and getting worse.
      I have made the cable adjustment and it still will not stay engaged unless I apply pressure to the knob.
      Has the modification been mass produced or is it design, up and weld?
      thank you all for any information you can supply.
      Update 30Sept2025
      I contacted Alpha Sport. Com and asked if they had shift lever in stock has the modification made to their stock.  They are unaware of any modification.
      I  made the modification myself. All went well, with the help of all the nots and photo in this group.  Thanks to all their hard work.
      The installation went well, too, except for one thing. The cable mount in the engine compartment, are (2) 19mm (might be wrong on size) nuts holding the cable in place, in front of the lever. Once I made the modification, the connection to the lever is very tight. Did I miss something. I believe the angle is too tight. Please advise
