Rear diff and swing arm
By Robert B
Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
By CarlB
I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential. I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
By mcraigchr
I realize that many of you do not have diesel machines. For those that do, this is for you:
Just wanted to post my experience this past week. Here in Texas, we had pretty good dip in temps. For 4 days it did not get above 25. At night, it was single digits or close to it. I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon). And up until this tank I was using Power Service (white bottle) for anti-gel. Never had an issue.
This tank, however, I switched to Stabil All season (anti gel). It is supposed to good down to -40. Zap. That is a big fat lie. I put in twice the amount called for in the instructions. Result was less than optimal. I drove the SxS 100 feet (to go get the mail) and it died. I looked at the fuel bowl and it was a cloudy, wax substance. So, the Stabil did not work. That said, I'm not sure that I ever tested the Power Service in the same manner. So I am not saying that one is better than the other.
What are your experiences? Are these products inferior? What do you folks in the northern states / Canada use? Am I missing something?
CC
By mehe
Now we are looking to you pro ATV riders to let us know if you think your group of people would fit in with ours.
