What do you do when
Go to solution Solved by Travis,
On 3/6/2021 at 9:01 AM, T-boss 410 said:
How many rolls do you figure you might need?
about 4 rolls of Gorilla tape, bring some glue in case we need to fix our hair too, LOL!
1 hour ago, Joe Breaux said:
I hear GORILLA GLUE works great on hair  and hardly burns the scalp at all
I heard that too--it was just a whiie back on  one of those "I can't believe people can possibly get any stupider." days--kind of like November 4, 2020.
Though in this one I'm not sure to whom the coveted "Moron of the Year" award (the "Dummies") should go--the nitwit that sprayed her hair with contact cement, or the idiots in the hospital that doused her head in acetone...
I give it to the jury thats gonna award her $5 Million from the manufacturer for not putting warning on label... DO NOT USE ON HUMAN HAIR.. or equine weaves .....next to the warning that says .... DO NOT EAT
Who was it that said that you can't fix stupid? Well then,  I guess we can just award them, huh?
Well, i blame T-BOSS for it acting up today since he didn't show up with the duct tape!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! CAN'T GET GOOD HELP ANYMORE!!!
As everyone here knows, I have no problem bashing Massimo for its poor quality and dismal service and warrenty , but I can say it does start everytime.. but its not 20 yrs old ,its only 3 .. still, that was funny
AINT ITTHE TRUTH?   I am On my way.... will GORILLA tape do?
Hey, I apologize. Seems someone bought up all the tape because they sold out of the Gorilla Glue. I guess there's a baldy convention in town and they heard about the idiot that tried to glue her hair on.
  • Haha 1
That^^^ would have perhaps  made some sense--the dipshit used it because she ran out of hairspray.
Well if it ain't included in the disclaimer, the company better be prepared for a lawsuit. Easy money nowadays.
I laugh each time I see a commercial for a  drug. They begin the list of side effects with "don't take this if you're allergic to it".
As a friend said to me "common sense isn't common, or everyone would have it". No more truer statement for the times we live in.
That's one of my daily chuckles too, along with the list of possible side effects ( sometimes including death,  which I have a hard time  classifying as a "side effect") that are worse than the ailment the drug is supposed to help.
George Carlin said," Realize 50% of the people in this country are stupid, then realize half of them are stupider than that"
    • By Hoppy one
    • By mehe
    • By Debbie Hogan
      Debbie fm  Texas
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
    • By AaronD1982
