I would like to know our member's thoughts on this. Are we lacking in any forums/categories here in the community? Should we add any?
Maybe a pictures and videos forum, or a tech forum, or any other type of category....
Any ideas are welcome!
Some time back I opened an account with webshots, http://community.webshots.com/user/TrooperFolk, and shared the user name and pass word with most of the posters here because it was easy, or at least I thought so, and lots of us have used it. It has lots of room for lots of photos and accepts pictures and videos. If you come up with something quicker and easier, I'm sure it would get used, I like it because you can post one photo and it opens the album and you can see all the photos even if you're not registered, important, for instance, look at Lennys post, http://www.utvboard.com/Nelson-Hills-ride-report-t867.htm,
What we need to do is learn how to write ride reports, like Lenny's and be able to put photos and videos in the report, maybe under it's own non-branded forum. I always enjoy reading my sons forum, here's what that forum looks like, just for an idea, http://www.advrider.com/forums/showthread.php?t=317714, lots of picts.
You could drop the KYMCO UTV line, or not.
That's my 2 bits worth.
Kinarfi
Kinarfi, Lenny's ride report was very good but after reading your sons forum, I would think this would be a better format for our site if we can do that. Your not linking to another site but as you said you can go on to see all the other photos if you want with webshots. Maybe, if we can post photos like the adrider forum, we could also keep up webshots too and get the best out of both worlds. I have tried to load videos onto webshots before with no success, that's why I suggested to add a video section here. The problem could be for me time lag causing it not to upload, I'm not sure.
Cheers Mike.
The same features with adding a photo in a thread like at http://www.advrider.com/forums/showthread.php?t=317714, are available here...I'm not sure what you would want to add except maybe a separate forum for Photos and Videos, or Ride reports forum..
All the photos in that thread are hosted at another site. All you do to add a photo in a thread is grab the url, then use the rte-image-button.png button, which will bring up a popup for you to enter the photo URL. That's it really.
We do not have a video upload section, I can look into adding functionality to display a Youtube video within posts....
Cheers Mike.
Added:
UTV Ride Reports
UTV Pictures and Videos
Also added category images to help with navigation.
  • 7 years later...
  • 2 months later...
    • By mehe
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Sharon
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
