2nd Annual Jamboree
23 members have voted
  1. 1. When would you like to have the Jamboree?
    • Fall
      13
    • Spring
      10
    • Summer
      5
  2. 2. What kind of trails?
    • Desert
      5
    • Mountains
      9
    • Rock Climbing
      4
    • Sand
      1
    • A combination of all the above
      13
  3. 3. How long should the Jamboree be?
    • 2-3 days over a week-end
      12
    • 4-5 days including a week-end
      11
  • Replies 70
  • Created
  • Last Reply
Top Posters In This Topic
  • 4 weeks later...
Sorry if I missed this, but did anything ever get nailed down for Quartzite? I was just out that way camping, a little south in an amazing caldera range called the KOFAs (King OF AZ) that is just a little south of Quartzite. We saw tons of quads going in on our way out and I think it would be a great place to ride. Of course, it would be unbearable during the summer; winter or fall only for the most part.
I got my camping permit today, got a new (to me) camper, an 83 Midas Motor Home, with 460 Ford and everything seems to be in real good shape, the Troopers running and the power steering unit is working good. So I guess I'm ready to come on down. Looking forward to it.
Kinarfi
Little town called Kemmerer WY
Couldn't figure out if you're going to the Jamboree or not, but if you need a place to stop, I have a great back yard to camp in if you need to.
kinarfi
    • By kmiller7351
      Trying to get running a 550 Colman running but I think head gasket went bad. Do i just replace with new gasket, clean up and replace or is there more to it?
    • By TimsBrickHouse
    • By dryvalleyboy
      The steering shaft is slipping,I checked it's tight as the bolt will take at the u-joint.. Is there a slot or something it may have jumped? This is right after the shaft enters the area under the hood.Thanks.
