Just an introduction as I have not been a member on this forum.
Unfortunately....it is not because I plan to be active here.
Due to the recent actions(or NON) of TJUSA and JMC this last year I have been forced to close the doors of my business EDGE Powersports. If I cannot get parts or machines then there really is no point. I have become discouraged by my lack of ability to service customers and their needs.
So now to the point of my post here.
I do have some leftover new parts that would fit the Renegade and Trooper machines. Though there is not much but perhaps someone here would be interested. These parts are dealer cost.
1 Box internals 800 renegade fron differential...These are new. They were removed from new renegade diff as JMC sent me the wrong one. -SOLD!
2 Starters 800/1100 Joyner....will fit either Renegade or Trooper -1 SOLD!
1 electric odometer assembley 800 Renegade
1 Trooper T2 rear drive line upgraded CV style
Sincerely
Glade Mason
Sincerely
Glade Mason
Glade,
Sorry to hear about the closure.Could you post prices? I know you said at dealer cost but what are the prices?
Glade,
ROCMOC just bought a starter and the differential parts.
The other starter $75
The rear T2 driveline $100
and the Speedo sender unit $45.
Sorry there is not more. I know you guys have had to adapt to this poor situation. I love the machines and regret this action that I have been forced to take.
Glade
Glade
Thank you for posting the prices,I will check on the starter.I think i have a spare,if not i will PM you.
Good price on the driveline. I spent $30 just for the replacement boot and the install is a pain.
rocmoc n AZ
I sent you a PM
Do you still have the driveline available?
Yes I still have these parts available
OH.....Just rounded up a throttle cable if anyone interested. I have 2 locker cables that I found too.
$30 for the throttle and $20 for the locker cables.
Glade
Glade
BUMP
im in need of spyder gears and pins for a 08 t2,does any one know if any other ones are compatible,or has anybody welded whats left of the spider gears <lincoln locker??? I HAVE PUT 20 MILES ON IT SINCE IVE HAD IT <i took it apart to put an upgrade kit in it and it was to late
bought it from a buddy that bought it brand new,he put 460 miles km? it sat is his garage 4 the last 2 years,just never wanted to play .well like a regular problem the set screw either sheared off or backed it self out ate up all the spider gears and broke both pins.ring and pinion look great they might of even shimmed those correctly.lol a couple of the ring gear bolts were stripped to but did not hurt anything yet .do you guys have parts or just full diffs?
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Ironhorse
      Purchased a new, leftover 2025 Bighorn Timberland 450LX.
      Dealer says to change the engine oil and transmission oil at 10 hours, then oil change every 30 hours.
      The manual says first oil change at 25 hours or 200 miles, and first gear oil change at 1900 miles.
      Are they being extra cautious?
    • By jamesxevan
      I’ve been eyeing a Hisun 500 soft cab enclosure upper doors setup for my UTV, but I’m really not sure if it’s a smart move. The idea of doors and some protection sounds appealing, but I worry they might just be a flimsy afterthought — weak zippers, thin plastic windows, maybe leaking or fogging when wet or cold. What good is “protection” if it doesn’t seal well? Also concerned about ventilation: with soft doors, does the cab get too muggy or stuffy?
      Anyone here use soft-cab doors on a Hisun 500 — did they actually hold up for real riding conditions, or did you end up ditching them for hard doors (or no doors)?
    • By Dewayne jones
