Interested in feedback on the 2011 & 2012 Troopers
By REDfletching
Spent today at a Honda dealership looking at their 520 side by side, then on the way home past our Lowes noticed they had several new UTVs on site, so we U-turned and ducked in there. We were impressed that all that came for $9,999 metal whole length skid plate, nice sized bed, roof, windshield, side mirrors, winch, upgrade looking tires… all of which would have added thousands of dollars to an already expensive Honda 520. Now Honda does have a great reputation from my trusted UTV experienced buddy, so it has that going for it.
By Ron from the Mitten
I purchased a 2008 Qlink Rodeo 700 a few years ago. I am from Michigan. Anyone know of any local repair shops? I had a dead battery, so I replaced that, started right up, ran the quad down the road, (this was last year), put it in the barn, shut it off. then a couple weeks later, went to go start it again, and nothing. I have power to the dash lights, horn, turn signals, wench etc, but nothing to the starter switch, and I hate electrical crap. Battery still reads 12.x volts.
Any suggestions would be amazing. I've owned it over 2 years, and haven't run 1 tank of gas through it. No time to screw with it, and very frustrated. Hoping someone can offer some advice of value.
By Hi sun 500
hello everyone, i just joined this forum to try my luck, few days ago i bought an old (dont know exactly), 2011/14 hi sun 500cc ""carburated"", was not running at the time, but i fell was a good deal and decided it to bring it home to play with it, this is the issue, i bought and installed a new carb, and pump, i repositioned the battery location and upgraded to a "car batt", reconnected the fuel lines and started it, but it only runs with the choke ON, i checked the bowl, it does have fuel,but for some reason wont inject it to run, i came across a video that say that ""the body small tank had to be connected for the cart to run" (was deleted when bought), sure enough i got it to run sporadically , but the so called ""small body tank'' often runs out of fuel and wont refill itself , i had to couple times do it manually, so how does that small tank works ?..what does it do?..and why if bypass it , the cart wont start?....any help?..thanks so much!!!
By alevins
Good day all,
searching here but cannot find the answer, Hisun been working fine and now reverse limiter seems to be engaging and cannot back up, cannot find a clear solution to disable the limiter. found a possible relay? not sure which one or to cuut a wire at ecu but a picture or diagram would be helpful
thank you for any help in advance
