June 11-14, 2010 -- 2nd Annual Trooper Jamboree
2nd Annual Jamboree
23 members have voted
1. When would you like to have the Jamboree?
Fall13
Spring10
Summer5
2. What kind of trails?
Desert5
Mountains9
Rock Climbing4
Sand1
A combination of all the above13
3. How long should the Jamboree be?
2-3 days over a week-end12
4-5 days including a week-end11
By GunnersTacklebox
By Mike Jenkins
I replaced the stator and now it will not start (run). It cranks fine, has fuel pressure, but will not fire up. I replaced the coil, no luck there.
By Grant
